Thread: how long after adding bleach..
    do you have to have your filter on approximately...
    25k Gallon Gunite Inground Pool
    Pentair FNS PLUS DE filter
    Pentair WhisperFlo WF-24 (seems like single speed)
    Bel Air, MD 21015
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: how long after adding bleach..
    An hour should be plenty. You can speed it up by brushing. If you have a wall whale brush, 5 minutes ought to mix things up enough - those things can move some water!
