Thread: Advice on First Pool Cleaner
    Hi Everyone,
    First, thank you to everyone on the forum. I just purchased a home with a pool in swamp mode and the advice on this forum is pretty much solely responsible for teaching me how to clean the pool.
    I'm new to pools and looking for advice on what type of cleaner to purchase. I've read over other threads and the overview and have some questions.
    First, here is my plumbing setup:
    1 Skimmer
    2 Jets
    1 Return
    Does the return go back to the filter or to the jets? When I backwash the filter, I notice if I don't get it quite clean, the Jets blow dirty water back into the pool, so I assume the water comes to them from the pump/filter.
    So my only option seems to be a suction cleaner or a bot. My pool has a V shape in the deep end. From all four sides in the deep end, the walls slope inward, creating a crevice at the bottom. I'm not sure if this will pose a problem for any cleaners. The pool is old and does not have drains.
    A bot sounds great and I was looking at the Dolphin Diagnostic, but many people on Amazon say the motor dies after 1-2 seasons. Any suggestions?
    Cole
    18x36 IG Vinyl, ~22,000 Gallons, WhisperFlo 1HP, Hayward 300 LB Sand Filter
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: Advice on First Pool Cleaner
    I think you are confusing 2 jets and 1 return with---------3 returns. And yes, any water coming back into the pool is coming in AFTER the filter. So, the returns are actually coming From the filter.
    Oct 2007
    Parkland, FL
    752
    dolphin was my first cleaner, nothing ever broke on it unlike the other robots I had, but dolphins couldn't change direction without using the walls, assuming thats not different now, I wouldn't do it because once the bag gets a little filled or the brushes wear a bit, it will not clean the pool.
    I've had a number of robots, blue diamond probably the best and has 4 years on the motors and pumps. and you can get it for under a grand.
    other option is go cheap and get the nitro wall scrubber, you can get them for 600 bucks right now, even less refurbished, 2 year warranty that you will likely have to use because they are made in china. but all the parts are available and you can swap the motors yourself. If my current blue diamond Remote control dies, I'm guessing 2 weeks or so with my luck, I'm buying either one of the two mentioned.
    BTW, the designer of these things told me not to bother with the remote control units, its just more parts to break.
    Quote Originally Posted by scolemann
    Hi Everyone,
    1 Skimmer
    2 Jets
    1 Return
    Cole
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    Mar 2011
    Austin, TX
    9
    Another vote for Blue Diamond (without remote control). I have only had mine for about a month but it is working very well. Used Polaris 280 and 380 for about 12 years. I figured if I was spending $800 I would get the Blue Diamond as it has had good reviews and has a 4 year warranty. I use it about every 3-4 days and it does clean our pool (16 x32) in about an hour.
    13,500 gal IG 3'-5', BBB (less Borates), Hayward DE filter, 400k BTU Hayward heater, 2HP A.O. Smith pump, 2 skimmers, Sunstone Pearl "Aqua Blue" surface, Colorsplash 3G light, Blue Diamond cleaner, A.O. Smith 6' slide, K-2006 test kit
    Jan 2011
    Palawan, Philippines
    21
    I have a very small kidney shaped pool, 20ft x 14ft, flat bottomed, constant 40" deep, tiled floor, near vertical painted concrete walls. I'm looking for a small budget robotised cleaner.
    I'm being drawn towards the simplicity, light weight and (definitely) the cost of the Aquabot Pool Rover Jr.
    Is this a good choice for my pool bearing in mind the small size? I'm not worried that it won't climb the walls.
    I already have a pool blaster max for small 'housework' and cleaning the built-in steps.
    In-ground 5000 gallon 'fun' pool. Integral 'wall-hung' combined pump/filter unit. 1hp motor. LED underwater lamp. Ozone generator. Floatron ioniser.
    Marooned on a tropical island paradise AKA 'home'.
