Thread: Update on my Algae fight
    Update on my Algae fight.
    It has been almost a week. The pool turned from bright green to dull green grayish. I am keeping the chlorine high but I have had a lot of rain.
    I took a sample to the pool store, here are the results.
    FAC =2.5
    TAC =2.5
    PH =7.5
    TA =80
    CYA =0
    TDS =1200
    Phosphates =300
    I added 2.5lbs of Conditioner by “Leslie’s”. It states it is 99% Cyanuric acid.
    14K gal gunite pool
    A.O. Smith B130 2.4hp motor
    Hayward DE2420L Filter
    Hayward SP3020X25AZ Super II Pump 2 1/2 HP Single Speed
    Aqualink rs4
    AutoClear salt system
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: Update on my Algae fight
    Has your FC been adjusted to "shock" value for the CYA you added? FC of 2.5 won't get you there.
    I believe I have however I am not sure. I am shocking morning and night per "BBB" post.
    14K gal gunite pool
    Aqualink rs4
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    The only way you can be sure you are shocking is to be able to ensure you are at shock level, via testing. Investing in a good test kit will save you money in the end. Not sure which "BBB" post you are speaking of but here is a link to our shocking instructions and a guide on kits....Good luck
    pool-school/shocking_your_pool
    pool-school/pool_test_kit_comparison
