Thread: Easy touch salt reads 3400 test strips 3020, what now?
    Oct 2010
    Eastern TN
    172
    Pool school recommends 200-400 ppm above recommended. Intelliclor recommends 3300. Should I leave things as is or trust strips and add salt?
    Plaster pool inground 22,000 gallons with spa. Pentair Intelliflo, IC40 salt generator, WiFi control/Easy Touch.
    Hayward 1.5 HP pump on 750 gallon spa. Sand filters. Auto chlorinator on spa. Auto water level. Dolphin M500. TF100 XL with Speed Stir. Apera Instruments AI311 PH60 Premium Waterproof pH Pocket Tester
    Re: Easy touch salt reads 3400 test strips 3020, what now?
    All of the salt tests are +-400, so those results are the same as each other within the precision of the tests.
    You will need to add salt before the end of the season, and most people find it easiest to do so early in the season while you are thinking about things like that. So I would add a little salt, say 200 to 300 ppm, now.
    Dec 2009
    Central Massachusetts
    2,690
    I have an Easytouch and IC-40. If the ET box is reading 3400, its fine. Leave it be, it' right where it needs to be.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Oct 2010
    Eastern TN
    172
    That is great info. Perhaps it can be added to Pool School.
    Oct 2010
    Houston, TX
    152
    I used salt strips and it turned out they were off by close to 800. Could've been a bad batch of strips, but will not use them again.
    15k gunite pool. Intelliflo VF. Autopilot SWG.
    2k separate spa with waterfall (ie: pain in the rear maintaining a separate body of water). 2HP Hayward Tristar pump.
