Thread: Enough horse power?
    Shpigford's Avatar
    Apr 2011
    Birmingham, AL
    50
    Enough horse power?
    I've got a 22,000 gallon pool with one skimmer, one floor drain, and 3 returns.
    My pump is a 3/4 HP Hayward Super Pump.
    Is that enough horse power for my set up? Would there be any benefit to a higher HP pump?
    22,000 gallon vinyl in ground with Hayward S244T sand filter and Hayward 3/4 hp Super Pump.
    Feb 2008
    Denton, TX
    5,061
    Re: Enough horse power?
    Unless you have some significant water features, you should be fine with the 3/4 HP.
    mas985's Avatar
    Pleasanton, CA
    11,741
    My pool is about the same size as yours, has TWO skimmers, a main drain and FOUR returns and I have only a 1/2 HP pump so I would even say that a 3/4 HP is too big.
    Mark
