Results 1 to 9 of 9
Thread: New Pool 1st numbers are in.... I think I need help!!!
    OK just did my 1st set of measurements with my TF-100 kit
    24' x 54" 13500 Gallon AGP with 54" wall (calling water level 48")
    Filled pool on city water and took 2 days to reach skimmer height
    I added 2lbs of the Lithium Hypo and I have the following readings
    I did not add my CYA yet
    Tempo 62 and rising (I got the Nat Gas heater running now too)
    FC 4.0
    CC .5
    PH 7.2
    CYA 0
    CH 90
    TA 70-80
    So where should I start 1st!? the .5 CC worries me so do I need to go and shock (I have my Sams Club bleaches at the ready)
    Tomorrow will be sunny near 80 So I am going to add 4 lbs of CYA now for sure to get me to about 30-40 CYA)
    Advice please!!
    Thanks
    Dan
    24' Round 54" Impulse Ovation AGP, 1.5 HP 2 Spd, 150 Sq Ft. Cartridge Filter, RayPak 130K BTU NG Heater, BBB in full effect!!
    Vist TFT Test Kits --- Visit Pool School ---
    Visit the Pool Calculator
    Re: New Pool 1st numbers are in.... I think I need help!!!
    CC is fine at 0.5 or lower. No need to worry about that.
    The only issue here is CYA at zero, but you already know about that.
    Feb 2008
    Denton, TX
    5,061
    I would address the absence of CYA first. No CYA in the water means that the FC from that expensive lithium hypochlorite will be bye-bye in short order come sunrise.
    I added the 4 Lbs. of CYA since I posted... figured I might as well get it going and be done with that portion
    The only useful item I have left on hand (Besides my Clorox from Sams) is 2 lbs of Sodium Carbonate for PH increase
    Then I have about 10 1 lb. bags of MSP , some "Clarifier" and stuff for Mustard Algae which all came with the package (including Lithium as mentioned)
    So in the absence of any recommend direct action on the FC / CC I will let it play out and do the Chlorine Test in the morning
    One note on Chlorine and I was fairly certain that I did both tests very accurately
    The yellow color quick test was (I thought in the 5-10 range (upper most color block) and I figured that was because I shocked the pool with the 2lbs of Lithium)
    but the FAS DPD came in at 4ppm (My wife was also watching and following along and we agreed on the drop count etc...)
    So I wonder which I did less accurately!! (I used the magnet mixer too, very handy indeed!!!)
    Thanks for the quick feedback Guys!
    The OTO chlorine test, drops turn the sample various shades of yellow, is inscrutable. Everything from 3 to 10 looks the same to me.
    New test this morning
    HEavy rain overnight
    FC 4.0
    CC .5
    PH 6.8
    CYA - still 0 Test question at bottom
    CH 90
    TA 90
    When I tun the test I can still easily see the black dot at the bottom of the tube
    am I missing something in the shaking or blending of the test agent with the pool water? Seems straight forward (Pool water to the bottom of the label, agent fill to the top of the label
    would over filling with agent result in a bad test? would under filling?
    I know I added 4 lbs of cya last night so I'm not going out to do it again or anything
    I am going to add Borax right now though
    Granular CYA takes up to a week to dissolve. I wouldn't bother testing it again until the full week is up.
    On the CYA test, once you have mixed the solution you can pour it into the view tube and back into the dispenser bottle several times to make sure of your reading. Also, if the pool water is cold, bring a water sample inside and let it warm up before doing the test.
    Thanks for the info Im sure that is part of my reading problem... the TF-100 kit that I received had a much longer tube with a bigger circle at the bottom than the one in Taylor site example (They had a water brick somewhat similar to the Chlorine/PH block
    Since the PH is pretty low and I added the sodium carobonate and the borax (I used the right corresponding amounts of each to equal the dosage)
    How long should I wait to retest and or let the kids into the pool? the water is now 76 and rising fast
    Thanks
    Dan
    Just did my numbers for tonight
    Off question before I put the numbers out we jumped in this evening after I finely did the electrical (Permanent that is, the temp lines had been used for a few days)
    I checked the PH and Chlorine the Ph had come up between teh 7.5 and 7.8 color blocks and my chlorine droped to .5 and 1.0
    so we swam!!!
    Why is my skin very dry feeling if my Chlorine was poretty low it wsan't that right?
    I pooled new water after swimming and they areL
    FC .5-1.0
    CC .5 (barely reacted back and forth this time)
    TA 80
    CH around 100
    CYA Finally getting a reading as it is dissolving in... around 15-20
    So given this I am Inclined to bring the FC up to around 4.0 and call it a night
    water is now 80 so the heater is going off in a bit tonight!! was nice to be able to get it up to usable temps so quick along with the cover (cover reel on order tonight!!, getting real tired of that!)
    Please let me know about ways to make the skin less dry or softern water etc..
    Thanks
    Dan!
