Thread: General question
    General question
    Just wondering why swg's recquire/work better with higher levels of cya?
    24X52 AG..Hayward DE 1HP pump..Intellichlor IC15
    Re: General question
    There are two separate effects. First, higher CYA levels mean less total chlorine used, so you can use a smaller SWG and it will last longer than it would at a lower CYA level. Second, SWGs somehow reduce several of the bad side effects of higher CYA levels that are normally experienced with other forms of chlorine. So the higher levels don't have any more problems than a lower CYA level without a SWG. No one really seems to know why that is, but it is probably due to the extremely high FC levels inside the SWG cell.
    Thanks for the reply..I just put in a swg (intellichlor) for my AG and my pool gets 100% direct sun every day..not an ounce of shade. I've always kept my cya levels around 30-40 but that was when I was using the tabs with added stabilizer. I've raised it to about 40 so far and everything has been good but it really hasn't been that hot yet here in NJ to really test it.
    The SWG will work at lower CYA levels, it just might not keep up at the peak of the summer with lots of people swimming, and the cell won't last as long.
    Gotcha..I will keep raising the level..no sense in shortening the cell life for no reason.
