Thread: My first big mistake of the year
    Apr 2010
    Cache , Ok 10 miles west of Lawton, OK
    37
    I messed up real bad ....I put in about 1 lb of cya, and using my test kit TF-100 I got no results for over a week (the water was in the 60's), So I added more. Now the test reads 90. I only use bleach, and except for leaving town for over a week. I don't plan on using anything but bleach. That being said, my pool is crystal clear no cc's and everything is going good. My TA is A little high at 110. Should I do anything or just keep on trucking on? I will try to keep my fc at 5 till it gets hotter then up to 7.
    Thanks for this great website!
    Retired Army and still serving.
    18X54 round above ground pool
    Sand Filter, 1hp pump
    TF 100 Test Kit
    Rover Jr robot cleaner
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: My first big mistake of the year
    90 is a bit high, but as long as you keep on top of it and don't get algae, it will be OK.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,600
    You need to maintain your FC levels per the CYA/Chlorine chart in pool school. If you're going to use bleach............just let rain water and water replacement let that CYA number drift down slowly unless you're in the mood to replace some water now. It can take up to a week for CYA to properly register on a test. Of course.............you know that now! Check your PH regularly and see if it likes your TA level or not. Adjusting Ph down with acid will also lower your TA over time.
    Apr 2010
    37
    Thanks for the reply. I was thinking the same thing, that as long as it stays clear, I am good. One question that I have. How will I know if my TA is too high?
    Thanks for all the reply's!
    TF 100 Test Kit
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    You'll know when the TA is too high by the pH making a large swing. If you test one day, and pH is 7.2, then you test the next and it's 8.2, then you'll know it's too high. By adding acid to lower pH, you're also lowering TA, and eventually, you'll hit a "sweet spot" with the TA, where the pH just "locks in" and you'll find that you barely ever need acid.
    12,800 gallon IG plaster kidney-shaped pool, waterslide, 800 gallon spa.
    1HP 2 speed Sta-Rite pool pump, 1.5 HP Sta-Rite spa jet pump. 2 skimmers, 1 main drain
    Purex-Triton TR-60 325 lb.sand filter. 2" Plumbing, Intex SWCG, TF-100 test kit.
    Link to pics of my pool! http://www.troublefreepool.com/my-oasis-t26558.html
    Apr 2010
    37
    Thanks for the reply, it doesn't make a drastic change but it will gradually go up, so I will work on that, once again thanks for all the replys.
    TF 100 Test Kit
