Results 1 to 12 of 12
Thread: Help! problem with my barracuda G3
    Ok, here's my problem. I just opened up my pool and was using my G3, it will only work for a few minutes, then the pressure in my filter ( Hayward sand filter)
    rises to 26 from 18 and my my pump stops suctioning. I turn off the pump then turn it back on and the same thing happens. It sucks fine for the few minutes then stops again, there is nothing in the hose or at the end of the G3 that might clog the system . My pump works great when I don't have it attached. I am hoping one of the guru's here on the forum can give me some advice.
    Thanks
    18x36, IG, Vinyl, 25,000 gal, S-200, 3/4 Super Pump, BBB or bust!
    I have a new bottom, new plumbing, and everything is working good!
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,412
    Re: Help! problem with my barracuda G3
    Did you empty the pump strainer basket? Check the G3 again and make sure nothing is stuck in the diaphragm. Have you backwashed the filter?
    Love TFP? Become a
    TFP Supporter!
    I have emptied the strainer basket, once it was full another time there was nothing but a few leaves. I also checked to make sure nothing was in the diaphragm, I pulled it apart just to make sure. I have backwashed the filter as well, just to make sure.
    Jul 2009
    Houston, Texas
    9,412
    Did you check all the sections of hose for a clog?
    Love TFP? Become a
    TFP Supporter!
    Yes, I even used the return jets to blow out anything that might be clogging the hoses
    Feb 2008
    Denton, TX
    5,061
    Once it stops, is there any suction at all in the cleaner line or is the suction through the cleaner line completely absent?
    there is no suction whatsoever. It will create suction again once I turn the pump off and on again.
    Feb 2008
    Denton, TX
    5,061
    Sounds like you have some sort of obstruction. I cannot think of any other reason as to why it would behave that way.
    Thanks for everyone's help I will keep at it.
    Aug 2007
    near the swamp
    806
    check the impeller for a clog
    Hi - you may have a clog in your vacuum line from pool to pump. Had a similar situation last year and found that my vacuum line was clogged with leaves. Once I cleared the leaves, problem went away. Have you tried putting only one section of hose in the vacuum port (keeping port open) to see if problem still occurs. That is how I found i had a vacuum line clog.
    15k gal, inground plaster, 15'x30', attached spa (w/spillover); Pentair FNS-48 DE filter(using Fiber Clear); w/1.5hp Whisperflo pump; gas heater (MiniMax 250); solar cover; location: El Paso,TX
    I haven't tried that yet, I will try that and see if that helps.
