Results 1 to 7 of 7
Thread: Pentair Intelliflo
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Pentair Intelliflo
    Does the Pentair Intelliflo only come in 3hp?
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Pentair Intelliflo
    Yes but are you looking for something larger? A variable speed is also a variable HP. As the speed is reduced, the energy used by the motor and the energy delivered to the water are both reduced. So in effect, the Intelliflo is really a 0.006-3.96 THP pump.
    Mark
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Quote Originally Posted by mas985
    Thanks mas985, I just am reading that now! I was about to edit my post! Lots to learn with these pumps! Not allot that I can find on mating my Aqualogic (p4) with these new pumps? Not sure buying the 8 program speeds will work. If I understand it correctly I have to buy a relay for every speed?(ie8) Not sure if any panel can handle 8 relays for 1 pump! But what about the board? And do I really need 8 different speeds? Not much that I can find on here about the interface with P4 and speeds?
    To get a P4 to be able to control more than one speed on an IntelliFlo pump you need an IntelliComm II board. Each relay you use on the P4 gets you one speed, so two relays gets you two speeds, three get you three speeds. Four speeds is the max with the IntelliComm II, but they can be any four speeds. A typical setup only needs one or two different speeds, occasionally three.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Depending on the software version of P4, you might consider a Hayward EcoStar variable speed pump.
    Mark
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    mas985, what version software do I need? Also is the software upgradeable or does it require hardware change?
    mas985's Avatar
    Pleasanton, CA
    11,741
    If I remember correctly, I think it needs to be 2.65 or higher but I would check with Hayward. But unfortunately to upgrade, you need a new main board which you can find on Ebay sometimes for less than $300 but if you have a tech do it, it will cost upwards of $500.
    Mark
