Thread: Chlorinator Help
    Chlorinator Help
    I just installed a new chlorinator, a Hayward TurboCell (T-15), when trying to install it, I am supposed to configure my AquaLogic PS-4. When attempting to do this, the AquaLogic won't show "Chlor. Config" under the Configuration Menu. Any ideas?
    Re: Chlorinator Help
    Welcome to TFP!
    Have you run the four wire communications cable between the AquaLogic and the AquaRite units?
    The T-15 unit came with one cord and I plugged it in to the AquaLogic unit. That was the only cord that came with the unit.
    Sorry, my previous comments are for a different setup where there is a separate SWG control box.
    There should be cell (the T-15) and a separate flow switch module, with two separate cables going back to the automation system. It won't work without the flow switch, which is a separate piece that installs in the plumbing close to but separately from the cell.
