Thread: how to remove window crank handle
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    The exterior door handle on my son's 01 Corolla has snapped off. I have a new replacement part, but in order to remove the old and install the new I have to remove the interior door panel. To remove the door panel I need to remove the crank handle for the window. Allegedly there is a retaining clip between the crank handle and the door panel that I can bend with a screw driver and the handle pulls straight off. After much searching and swearing, I have not found said retaining clip.
    Any ideas how to remove the window crank handle without damaging the car?
    Love TFP? Become a
    TFP Supporter!
    Aug 2007
    near the swamp
    806
    Re: how to remove window crank handle
    I bought that tool for about $6 @ Autozone.
    Jul 2009
    Houston, Texas
    9,377
    Thanks! I'll give that a shot.
    Love TFP? Become a
    TFP Supporter!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Be aware that the clip is spring steel. When you get it to spread and push out, it may fly away. So do the job on the driveway, not the lawn. The clip is shaped like the Greek Omega Ω. That tool catches the ears and pushes things out. The tool is usually sold at a decent auto parts store for a couple bucks. If the handle's been off before, it may have been installed 180° off, so try pushing from both directions.
    Apr 2011
    Somewhere on the Emerald Coast
    156
    I used to use a small pair of needle-nose pliers. A lot of times it was hit-or-miss but it eventually worked.
    It seemed that my motorcycles had those blasted clips everywhere!!
    20,125 gal. (2,690.6 c.f.) In-Ground / Concrete (Gunite) / Pentair Tagelus TA-60-60D Sand Filter / Pentair Whisper Flo Pump Model WF-24 @ 1HP / Hayward Veri-Flo Valve Model 710 / Taylor FAS-DPD K-2006 test kit / Pool School student
    Feb 2008
    Denton, TX
    5,061
    This is just another example of why this is the greatest forum evah!
