Results 1 to 13 of 13
Thread: What search terms would you use?
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    I'm working on improvig the search rankings of the site. One of the things I need to determine are what search terms are people using when looking for help with swimming pool care.
    I have my own ideas of what terms I would use, but that may not be the same as others. What search terms did you, or would you use, if you needed help with your pool? These can be general terms or for specific issues.
    Thanks for your help,
    Sean
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    Guest
    well i typed
    pool forum- to find any type of forum that talked about pools.
    what i would use now is
    pool help
    help with new pool
    how do i take care of a pool
    FWIW
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    "Green Pool"and "Green Water" would have to be high on the list. "New Pool Advice", "Pool Problem", "Pool Builder Problem", "Pool Leak".
    Guest
    heating pool
    pool pump
    sand in pool
    vacuming pool
    pool filte trouble
    bubbles in return
    pool covers
    pump looses prime
    cloudy water
    ktdave's Avatar
    Katy, TX
    888
    "cloudy water" "fix.......pump, filter, liner, etc."
    11,000 gal. gunite w/midnight blue and white pearl PebbleTec
    Intelliflo 4x160 pump
    Intellichlor IC-20 SWG
    Pentair cartridge filter 420 sq. ft.
    Mastertemp 400K BTU heater
    Legend Platinum cleaner
    Pool School
    JasonLion's Pool Calculator
    TF Test Kits
    Guest
    off topic
    dave isnt it funny how we always post the same thing at the same time.
    ontopic
    pool building
    broken pipes
    ktdave's Avatar
    Katy, TX
    888
    Quote Originally Posted by Rollin Thunder
    Great minds ( with red necks) Think alike!
    Pool School
    TF Test Kits
    Guest
    Quote Originally Posted by ktdave
    Aug 2007
    Riverside, CA
    88
    Swimming Pool repair, electrical, plumbing
    Swimming Pool algae
    Swimming Pool ideas
    Swimming Pool care/upkeep
    Swimming Pool build
    Swimming Pool landscaping
    Swimming Pool scale
    Swimming Pool chemicals
    Swimming pool DIY
    Swimming pool owner/builder
    Swimming pool chlorine, bleach, BBB, muriatic acid
    Swimming pool salt water chlorine generator, swcg, swg
    Also, common incorrect spellings of these terms
    ~Debbie~
    28k, 22'x37' freeform 3.5'-9'deep
    w/ 7.5' freeform spa raised 18" above pool, Gunite/dark gray plaster, 3 rivers flagstone,
    Aquarite SWCG, Aqualogic ps8, Frog, Colorlogic LED lights.
    Completed 2/06, in Sunny So Cal!
    I have always just searched for the specific problem I was having. The search that indirectly led me here was "baquacil red slime." People in general don't just look for a pool care forum unless they are having a problem and then they search for terms specific to their problem.
    As a writer for About.com we get SEO drilled into our heads. The best you can do, I think, is to encourage good detailed "stickies" for the common issues, and make it a place where people are comfortable posting. The more posts you have, the more likely it is that that issue will come up in a search. Optimizing the "home" page is kind of a futile effort, IMO. Think of every page as a potential entry to the site and work on making navigation to the rest of the site more obvious.
    Two things you can do in that regard:
    • 1. Put the "jump to" menu at the bottom of the page so when someone finishes a thread they can use it to poke around more.
      2. List some related topics at the bottom of the page, if your forum software supports this.
    Attached Files Attached Files
    Sue
    Current Pool: IG Concrete / 11,000 gal. / Sand filter / Solar heat / Hayward CL200 / Screened / TF Testkit
    Pool owner since 2001. Thanks TFP for helping me convert off Baquacil after six years!
    Some of these may have been mentioned already...
    baquacil - what I searched when I found Ben's site
    pool maintenance
    swimming pool maintenance
    pool care
    swimming pool care
    salt water pool
    algae in pool
    pool chemicals
    chemical-free pool
    chlorine-free pool
    gross pool water
    help with pool water/pool chemicals/algae in pool
    I tried to google us once using several different terms and never found TFP, but that was a while ago. I am trying to remember what terms I used...
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Butterfly's Avatar
    South Carolina
    10,045
    Well, probably some duplicates, but:
    new pool owner
    green water
    residential pool
    pool maintenance
    cost to maintain residential pool
    help with pool
    Found Ben's site w/that stuff....I think. Good luck!
    Joyce
    You're done SLAMing when:
    SeanB's Avatar
    Mar 2007
    2,622
    These are great. Keep them coming. I need lots more!
    TFP Founder
