Thread: cya added with chlorine tablets
    is there a way to figure how much cya is added by using triclor pucks?
    24,000 gallon ig fiberglass pool
    1 hp hayward pump
    hayward sand filter (250 lb)
    madisonville, ky
    Mar 2009
    Huntsville, AL
    156
    Re: cya added with chlorine tablets
    You can use the pool calculator. Enter your pool volume at the top and then scroll down to the bottom of the page and use the section for calculating the effects of adding chemicals:
    http://www.poolcalculator.com/
    27K gal, IG vinyl, 1.5 HP pump, 24" sand filter, Goldline Aqua Plus SWG
    Trichlor pucks are usually about 7 ounces each. Each puck adds the following amounts:
    Pool volume......Cyanuric acid added...........Chlorine added
    In gallons........ by (1) 3-inch tab (ppm)...... per tab (ppm)
    10,000..............3.0................................4.8
    15,000..............2.0................................3.2
    20,000..............1.5................................2.4
    25,000..............1.2................................1.9
    30,000..............1.0................................1.6
    Support the site
    Jan 2009
    Cupertino, CA
    1,966
    Or, trichlor adds 6ppm CYA for every 10ppm FC.
    --paulr
    BBB "Intermediate Swimmer"
    Quote Originally Posted by PaulR
    --paulr
    That's a good rule if you are adding a dose of chlorine all at once, but most people don't think about ppm chlorine added when using tabs. They count the number of tabs used, and use tabs to maintain a certain level.
    Support the site
    Jan 2009
    Cupertino, CA
    1,966
    Hm, true, just thought I'd point out the relationship. Not clear whether diverman57 is a regular tab user, or somebody like me using N tabs to get CYA where it wants to be. I've found asking the Pool Calculator to tell me how much CYA from 10 tabs is a good starting point.
    --paulr
