Thread: is too high borate level a problem?
    Oct 2010
    Houston, TX
    152
    Went a little overzealous on the borates for my spa. LaMotte strip reading says 80ppm. Is this a problem/hazardous? Do I need to do a partial drain, or should I just leave it?
    15k gunite pool. Intelliflo VF. Autopilot SWG.
    2k separate spa with waterfall (ie: pain in the rear maintaining a separate body of water). 2HP Hayward Tristar pump.
    Re: is too high borate level a problem?
    Levels up to 80 are fine, just not necessary. I don't recommend levels above 80.
    Dec 2010
    San Diego, CA
    1,137
    Once you get your borate levels up to 50+ what do you use for pH increaser if you usually use borax?
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    Unless you are using trichlor, stick with Borax. You will lose borates more quickly to splash out than you will add with borax.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    In the rare event I need to raise PH and my Borate level is on the high end of the 50-80ppm range, I just take out my trusty $5 pvc aerator or water fountain and enjoy the show. PH+ or washing soda will work too but will also raise TA much more than borax
    Dec 2010
    San Diego, CA
    1,137
    Thanks guys! Spaced on the aerating option.
