Thread: Ph a little high, TA very low
    Opened couple weeks ago, no swimmin yet, still a little cool, trying to get a handle on taking care of the water.
    My Ph is just a little high, looks like 7.9ish, and TA is very low, like 2ppm. Should I bring the Ph down a little first, or bring the TA up a little at a time first?
    I know I can get to both, I'm curious how the order you do these things affects the big picture. It seems like I need to get some TA going before adding something to lower Ph, but I wanna know the right way to go about it, if it matters.
    Thanks
    1992, 19,000 Gallon In-Ground Kidney Shaped Gunite, 1 HP Pump, 350 Lb Sand Filter, Polaris 380/PB4 Booster Pump, converted to BBB method April 2012
    Feb 2008
    Denton, TX
    5,061
    Re: Ph a little high, TA very low
    How are you getting your test results? TA should result in increments of 10 so 2 ppm wouldn't be a valid result. Are you sure you don't have 20 ppm?
    Correct your pH first and then raise your TA with baking soda.
    There are many ways to do this. I would bring the TA up to perhaps 40 first. Then adjust the PH just a little low. Then raise the TA further. That will give you more control. With TA really low it is very very difficult to adjust PH without overshooting your target level.
    Quote Originally Posted by 257WbyMag
    Yes, 20ppm is what I meant. Just using a regular drops tester, only took two drops to clear up on the TA test.
    Thanks Jason, I will bring the TA up a bit first.
