Thread: Safety Net use Same anchors as Merlin Smartmesh Cover
    Feb 2011
    Cincinnati, Ohio
    106
    After our pool is completed the PB is going to install a Merlin Smartmesh cover. I was wondering if anyone knows if there is a safety net available that can re-use the anchors already there for the cover?
    I'm planning on the cover for off-season and looking at a mesh fence or net for in -season use.
    Thanks.
    18 x 36 IG Vinyl Liner 28K Gallons
    Pentair Intelliflo VS+SVRS, Pentair CC + 420 Cartridge Filter, Easytouch CP with IC40 SWG
    2" Suction and Return Lines - 2 skimmers, 6 returns
    Dolphin Diagnostic Advantage Robot
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Safety Net use Same anchors as Merlin Smartmesh Cover
    I don't know for sure, but I think the anchors are pretty much all the same. You just have to supply an accurate design when you order the cover (someone correct me if i'm wrong).
