Thread: Accurate Volume Calculation
    Pool diagram attached. I calculate 2,816 cu. ft. x 7.5 gallons per cu. ft. = 21,120 gallons - assuming 6" below liner track for water level. Am I accurate or am I missing something. I just found the diagram this morning.
    Thanks!
    Gerry
    Pool: 25,000 gal.(appx.)/IG/Vinyl/DE
    1.5 HP superpump / Filter Flow Rate - 72gpm (as per spec.)
    Hayward 300,000 BTU natural gas heater / Polaris 380
    Long Island, NY
    Jun 2010
    TT
    85
    Re: Accurate Volume Calculation
    if you're into that kind of stuff, Google Sketchup will allow you to represent your pool in a line drawing, and use a freely available plugin to instantly calculate the volume in g/l.
    Just a thought.
    21,000 is certainly a good enough estimate to use when calculating the amount of chemical to add. Remember that you can never get an exact answer since the water level varies.
