Thread: Return placement
    Feb 2011
    Sicklerville, NJ
    80
    Return placement
    Sitting around waiting on the town to approve permits so I thought I'd do some pre-planning for my plumbing design. Skimmers are set (precut into walls) so just thinking of where and how many returns to use. I guess 2 returns for the steps are mandatory since the prevailing wind is going to pile stuff there otherwise... also thinking 1 across from each skimmer... then a fifth one in the top middle somewhere to try to set up a counter-clockwise pattern. Any good? The equipment pad will sit about 15' behind the steps on the right.
    25k gal Lazy-L, vinyl liner, poly walls, swimout spa, diving board, TurboTwister slide.
    Hayward 2HP 2-spd pump, Pentair 2HP spa pump, Hayward 30" 500lb sand filter.
    Goldline Pro Logic PS-8 automation/SWG. 2 LED ColorLogic 4.0. 8 Jandy deck jets. MX-8 cleaner.
    Re: Return placement
    There are a couple of ways of doing it.
    If you go for one big counter clockwise loop you definitely need something in the bottom right as that will otherwise be a dead area.
    You might be better off going for a figure 8 motion, with the water on the two sides spinning in opposite directions: left counter-clockwise and right clockwise.
