Thread: At what point will having too high a FC harm pool liner?
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Hey guys,
    Hope you all had a good winter. Long Island was a mess. Opened the pool to a lovely green swamp.
    I know I commited a sin, but I didnt check my CYA before shocking. I just brought my FC level up much higher than it probably should have been and backwashed 3 times a day
    My question is (Assuming a low CYA since I have no idea what it really is) is there a point where a FC level in the mid to high 20s can damage the liner of a pool.
    I kept my FC at or around 26 while shocking. It took 4 days, a lot of scrubbing, and a lot of backwashing but finally the pool is crystal clear. Was that dangerous to the liner? Im not swimming in it.
    18x38 Inground Liner (25k gal) Paver surround, multi-speed pump, DE Filter, Raised spill over spa, TF-100
    30,421
    Re: At what point will having too high a FC harm pool liner?
    Well, it's completely after the fact, but if your CYA was zero, that's pretty high and much more FC than I would be comfortable with for that long.
    Bleaching of the liner probably occurs before any physical damage so, if you can't detect any color loss, you are probably fine.
