Thread: change motor to 2speed
    Dallas TX
    186
    I have a single speed motor - Specs:
    AO Smith Centurion 1.5hp
    Threaded Shaft
    Square Flange 56Y
    SF 1.5
    fr y56y
    hp 1.5
    volts 230
    I want to change it to 2 speed. Would the Emerson SQH15FL2 be a direct fit?
    1.5hp
    230V
    1.50hp
    56Y frame
    Pricing seems to be $200, which is great!
    Understood I would also have to replace my old Instamatic timer with a 2-spd timer
    Am I missing anything? Suggestions? This should be plug-n-play, correct?
    Understood I'll need a new pump seal - already on hand.
    33k Gunite, CompuPool CPSC48 SWG, Sta-Rite System 3 DE, 2.25hp dual-speed, POOLVERGNUEGEN Pressure-side
    Apr 2010
    Buckeye, AZ 85326
    619
    Re: change motor to 2speed
    I cant help with the fit of your pump but I did see a spot on the local news that our power utility is offering big rebates if you switch to a 2 speed pool pump. Maybe you can find the same type of thing in your area. Good luck .
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    38,507
    Quote Originally Posted by Shane1
    What kind of AZ rebates are we talking about? I did a quick search and found this:
    http://www.aps.com/main/green/choice/choice_109.html
    $200 rebate for variable
    $100 rebate for 2-speed
    That match what you saw?
    ETA: I now see that APS is a utility company ... not in Tucson. Oh well, have to check out locally.
    Dallas TX
    186
    Wahl then, the AZ discounts won't do much good for me here in TX
    Looking for advice on if it'll fit!
    Thanks
    Apr 2010
    Buckeye, AZ 85326
    619
    I wasnt trying to hijack your thread just trying to possibly save you some cash.
    jblauert I sent you a PM with the info that was on the news.
    2' Powerfall
