Thread: Raising CYA?
    Raising CYA?
    Got the CYA down last year to around 80 after converting to bleach and I added bleach almost every night. We had a leak last winter water remained below jets. With the addition of water after fixing the leak CYA is between 30-40. I'm having to add a lot of bleach every night. My pool is in full sun all day. Would it be wise to up the CYA? What would be a better number? I have some old pucks or should I use the sock method?
    Do I need to adjust anything else? Is TA and CH too low? Here are my numbers last night before adding bleach
    FC 4.0
    CC 0
    PH 7.5
    TA 70
    CH 100
    CYA 30-40
    Thanks for any input.
    16X32 Rectangular In Ground Built 1998, New Vinyl liner and Motor 8/2012, 19,000, Hayward Sand Filter, Hayward Super Pump,PoolPilot DIG-220 SWG, 2 Skimmers, Main Drain, Clean Machine Robot, Full Sun, Bleach, TFTest Kit
    Central, VA
    30,431
    Re: Raising CYA?
    How much?
    Re: Raising CYA?
    9 - 12 cups sometimes more had a lot of rain this last week
    Central, VA
    22,553
    Re: Raising CYA?
    AT 9 to 12 cups you're only adding 1.5 to 2 ppm per day. I'd say that's pretty normal.
    You can raise it up to 50 ppm but I don't think it's going to help you very much and I wouldn't go much higher than that.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Re: Raising CYA?
    I lose 3-4 ppm per day in full sun when it heats up with CYA of 50ish as a reference for you. Averaging about 2ppm right now. But that's gonna change! Water temp is around 75 lately.
    Re: Raising CYA?
    Thanks, I'll leave it for now and see what happens when it warms up.
    Central, VA
