Thread: Question but related to new plaster pool
    Different question but related to new plaster pool. My PB is acid starting my pool and will brush it and balance it for the first two weeks. But for some reason he has installed a temporary pump running 24/7 to circulate the pool water rather than use the pool equipment on the pad. So the brushing debris stays in the pool.
    Does it make any sense? Obviously it was a bit more work on his part versus just using the pad. Is there any downside or is he being extra nice to my equipment by not running highly acidic Water through it?
    24k gallon inground with 500 gallon spa, 580sqft Jandy cartridge filter, Jandy ePump 2HP variable speed pump, Jandy 1400 SWG AquaCal Heat Pump, Diamondbrite Aqua Quartz plaster
    Re: Question but related to new plaster pool
    If you have a heater with a copper heat exchange coil, which most common heaters have, you don't want to run highly acidic water through the heater. Having some extra dust in the pool for a couple of days won't be a problem.
