Results 1 to 16 of 16
Thread: Replacement for a Sta-rite max-glas motor
    cheesehead's Avatar
    May 2011
    West Michigan
    30
    I am needing to replace my 1980's model sta-rite max-e-glas 1 hp (SF 1.55) motor w/square flange. I would like to go with a similar model in a dual/2 speed motor.
    Could someone recommend some current 2 speed models that will bolt up to my existing pump?
    Should I stay with Sta-rite?
    Is it possible to get a larger high speed and keep the low speed the same?
    Or would it be more cost effective just to purchase a new pump/motor assembly?
    Sorry for all the ??'s
    Thanks!
    25,000 gal. bromine, IG plaster pool w/sand filter, 2 spd, 1hp, 1.5fr sta-rite pump.
    cheesehead's Avatar
    May 2011
    West Michigan
    30
    Re: Replacement for a Sta-rite max-glas motor
    Quick update - I just received a call from the pool company that opened the pool (and discovered the seized motor). The service person informs me that I cannot just switch out a single speed motor to a 2 speed motor using the same pump. Is this correct?
    If so what are some recommended brands of pumps with 2 speed motors?
    Also what are some recommended online sites for purchasing pumps?
    22,553
    That is very wrong. It's not an issue at all to change a single speed motor to a 2-speed motor. You don't have to change anything but the motor. It prudent to change the shaft seal but not because it requires a different size.
    What type pool do you have?
    If it's an inground the Whisperflo's are highly thought of.
    cheesehead's Avatar
    May 2011
    West Michigan
    30
    Whew! Thank you Bama!!
    I have a 18' x 36' in ground cement pool with a 5'x5' inground spa.
    If I do not need to change out the pump itself should I stay with a sta-rite replacement motor or will a Whisperflo bolt right up as well?
    Also any online source suggestions??
    22,553
    Any 56 frame motor of the same high speed hp matching your's will bolt right up. Make sure you get the same voltage too.
    cheesehead's Avatar
    May 2011
    West Michigan
    30
    So if my current motor is 1 hp then that is the max high speed rating I can go correct?
    Any recommendations on 56 frame 2 speed motors with a speed switch? Or is this available?
    Thanks!
    22,553
    Search for dual speed pump motors. There are lots of places to buy them.
    Here's what you need to know off the old motor.
    Hp = 1
    SF = ? (Service Factor)
    Voltage= ?
    Frame = 56
    That's about it.
    cheesehead's Avatar
    May 2011
    West Michigan
    30
    Hp = 1
    Voltage= ?
    Frame = 56
    That's about it.
    Thanks. I will begin my search!!
    Hp = 1
    SF = 1.55
    Voltage= 220v
    Frame = 56
    22,553
    What you want to look for is something that equals 1.55 SFHP. You get that by simply multiplying the HP X the SF. In other words, as long as the SFHP equals or slightly exceeds 1.55 you're good to go. (I.E. you could get a 1.5 hp motor with a 1.0 SF and that'd be fine.)
    cheesehead's Avatar
    May 2011
    West Michigan
    30
    Would this give me better suction when vacuuming?
    Dallas TX
    186
    Just a note - for the 2spd function to work, a compatible timer or manual switch will have to be used as well. Otherwise, your old Instamatic timer (assuming that's what it has) will only turn on and off one speed.
    Vac power will be the same on Hi with the same rated total HP motor... Flow is dependant on the speed of the impeller, not the motor driving it.
    33k Gunite, CompuPool CPSC48 SWG, Sta-Rite System 3 DE, 2.25hp dual-speed, POOLVERGNUEGEN Pressure-side
    22,553
    acroy is correct. It won't make a difference in the operation of any equipment.
    cheesehead's Avatar
    May 2011
    West Michigan
    30
    Thanks for the input!
    I found a Hayward Max-flo complete 1.5hp pump set up for basically the same price I was quoted for a replacement motor for my current pump.
    http://www.sunplay.com/Hayward_Max_F...sp2810x152.htm
    Any thoughts on this model?
    Also would it benefit me to step up to the 1.5 hp pump/motor if I decide to replace the entire pump?
    As for the switch. Can I wire up something as simple as a toggle switch to switch speeds?
    22,553
    If you buy a new 2-speed pump it should come with a switch. If not, it's an option. I wouldn't go to a bigger pump.
    cheesehead's Avatar
    May 2011
    West Michigan
    30
    I've searched just about every pump manufacturer and have yet to find a 2-speed pump with a switch. Does anyone know of one that I am overlooking? If not wouldn't a simple toggle switch rated appropriately work?
    22,553
    Not really. It needs to be a special switch. Its a double pole double throw center off. Whoever you get it from should be able to provide the rear cover with one.
