Thread: to shock or not on opening
    Diver's Avatar
    May 2011
    South of Boston
    450
    I want to apologize in advance for asking so many question in my short existence on this forum I’m just trying to be prepared for different scenarios before opening the pool and be ready upfront and not to figure out how to deal with consequences of lack of knowledge later.
    What is the general consensus on shocking at opening and if it needs to be done? My water is still below 60 degrees and looks kinda ok-ish. Chlorine levels are either non-existing of extremely low. I understand that if I have a dead opossum in the pool or if the pool is all green, then I don’t have a choice but to shock. But if it seems somewhat ok, then do I follow the general guidelines for shocking – CC more than 0.5, overnight drop is 1.0 or less? The criteria for shocking also includes FC being at zero, but I assume this is more relevant for regular maintenance time, not the opening.
    Or should I shock it anyway?
    Thank you.
    26K In-ground Vinyl Pool | Hayward DE4820/SP0710XR50 filter | 1.125 HP Dual Speed Hayward Super Pump | Aquasol Solar
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,602
    Re: to shock or not on opening
    Add some chlorine to bring it up to what your cya level requires when you open and see how it goes. You may be just fine with that water temp at the moment.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Some people will tell you to do it, others will say it is a waste of money. Overall it is a personal choice, betting the odds, etc.
    Ike
    22,549
    Here's what I did and what I recommend everybody do. Opened the pool and ran a full set of tests on the water. I brought the FC up to the proper level for my CYA and performed the OCLT. It passed, so all I had to do was keep the FC where it needed to be and adjust the other stuff.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
