Thread: First pool need advise
    Aug 2007
    Silver Springs Florida
    6
    Hi new to forum and have been reading quite a bit but don't want to make any mistakes. My pool is 15 x 30 screened and has some sort of automatic pop head cleaner which isn't working now,the filter a pleated and it looks like brown sand. Does anyone have any ideas?
    Just got back from pool store and here are the readings.
    chlorine 3.0
    Ph 7.8
    alk 100
    cal 250
    sta 50
    I closed on house on Monday cleaned out filter and it looked like it had a brown sand like particles didn't see any green in filter. pool was green added 4 gals 10% from Lowe's most of the algae is now gone from light green to cloudy blue in some area and there looks like there is still some green on bottom cant see bottom of pool.
    pool store says 2 caps of yellow treat 2 jugs of chlorine today and 2 tomorrow. Would this be the proper course?
    How much chlorine is in the yellow jugs and what percentage is it. I still have 4 gals of the 10% ???
    21' Round AGP, 10k gallons - 2hp 2spd pump - 300lb sand filter - Stenner Chlorine Injector - Pool Rover
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Bring your chlorine back up to 15ppm and get a good test kit. Tftestkits.com sells a good one.
    Aug 2007
    6
    Do you know what the percent of chlorine from pool store? Any idea what the brown sand like stuff would be? You said to bring up chlorine To 15 ppm does that mean don't use the yellow treat?
    Thanks for your help
    SW Indiana
    9,199
    Quote Originally Posted by farefax
    I'd just stick with chlorine. Pool store chlorine is usually nominally 10 or 12%. The brown stuff may just be dirt that has blown or been tracked into the pool.
    Aug 2007
    6
    Thank you will just use the chlorine. Waiting on my Taylor test kit to get here.
    Thank you
