Results 1 to 14 of 14
Thread: New liner install.
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    New liner install.
    Hey folks, been a while since I've posted here. Our liner was showing its age (23 years) last year, brittle above the tile line, stretch holes in the corners, etc. We decided when we closed that we would replace it in the spring as we didn't want a catastrophic failure when full.
    Empire Pools came out and measured and ordered the liner, install is set for June 1-3.
    In the meantime I've pulled out most of the liner (save money if I get rid of it myself) I'm leaving the coping for him to remove. Here is a crappy cell phone pic of the liner out.
    The walls and concrete floor look like new, considering the pool was built back in 1988.
    [attachment=0:2kbebxnb]IMG-20110505-00071.jpg[/attachment:2kbebxnb]
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    TripleB4me's Avatar
    Jun 2007
    Maryland
    224
    Re: New liner install.
    WOW, 23 years for a liner! I'd be extremely happy if I can get half that. Do you know the manufacturer and thickness of the old liner?
    20x40 IG Vinyl, 1.5 HP Whisperflo, Sta-Rite System 3 (300) Sq. ft Cart
    Intellichlor IC40 SWCG, 125,000 BTU Pentair heatpump, Polaris 280
    7' IG FG Spa, 2 HP Whisperflo, Pentair Dynamic III Cart (100) Sq. ft
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Unfortunately I do not know the manufacturer of the old liner, it was fairly thick, and the installer said it was high quality, so I'm guessing 12mil? you can see the blue colour of the underside, the water side was mostly white from fading. It will be different going to a darker blue liner.
    Feb 2011
    Sicklerville, NJ
    80
    That pool looks very well built. I'm guessing it was covered most of the year? That's one of the (few) benefits to a short swim season... the liner is covered and protected from UV so tends to last longer, barring other physical or chemical destruction.
    25k gal Lazy-L, vinyl liner, poly walls, swimout spa, diving board, TurboTwister slide.
    Hayward 2HP 2-spd pump, Pentair 2HP spa pump, Hayward 30" 500lb sand filter.
    Goldline Pro Logic PS-8 automation/SWG. 2 LED ColorLogic 4.0. 8 Jandy deck jets. MX-8 cleaner.
    Aug 2010
    MA
    173
    Quote Originally Posted by Molson
    12 mil would be a really thin liner.
    Completed: June 2011
    18' X 38' IG Vinyl, 3' - 8' depth ~ 24K gallons
    2 skimmers, 2 wall suctions, 3 returns, 1.5" piping
    Hayward Equipment: 1HP Tri-star 2-speed, Aqua-Plus SWG,
    Star-Clear Plus 175 sqft cartridge filter, Colorlogic 4.0 LED
    The Pool Cleaner 4X(suction)
    2011 Jacuzzi J-280 Hot tub
    Mar 2007
    Coastalish 'down easter'
    4,160
    Hey Molson
    Nice looking shell.
    Might I ask why you're waiting for the PB to pull out the rest of the liner?
    Of course you realize we're gonna want more pics in 2 weeks
    Luv& Luk
    -Ted
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Thicker than 12mil then. I have no idea.
    Hey Ted! Good to see you.
    The reason I left the rest attached is if I break the coping when removing it, I am replacing it. If he breaks it, he is replacing it. I watched him remove a section of coping, and it didn't like to cooperate. I may get adventurous, or I'll just leave it for him.
    MajorDIYer, you are correct, the pool is covered for the winter Oct-May, and with a solar cover in the summer most of the time. I also assume that assisted with the longevity. It was also a bromine pool its whole life. I'm switching to SWG this year.
    Here's the pool while it was draining. I will take as many pics as I can during the install.
    [attachment=0:1d0yogmr]pooldraining.jpg[/attachment:1d0yogmr]
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Hey Ted, I popped some more of the coping off last night. It wasn't as hard as I thought, just need to be gentle. Getting the liner out of the track is a tough job though.
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Liner is going in on Monday! Also, the coping I have is no longer available. So we have to be extra careful when removing the rest!
    4JawChuck's Avatar
    Jun 2010
    Winnipeg, Manitoba, Canada
    223
    Looking good!
    55 Kilolitre in-ground 18'X36' vinyl lined kidney shape, 1HP pump, Jacuzzi 250lb sand filter, RayPak Delta T 200K BTU natural gas heater. New PoolWerks "Blue Diffusion" liner on May 26th-2011
    Avatar is my pool!
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Here are some pictures I took with my blackberry. I'll have a time lapse, and better pics up soon. All went well, liner went in without a hitch, SWG plumbed in and ready to go. 5.5 loads of water @ 3000 gal each. My pool volume is a LOT smaller than I originally thought! Only 16,000 gals.
    Sep 2009
    Greentown, IN
    914
    Looks really nice! I imagine it feels like a new pool to you
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Yes! Its just a like a brand new pool.. pretty exciting.
    Here is a quick time lapse, I didn't take enough shots, but you get the idea.
    http://www.youtube.com/watch?v=UgcTKjv04F0
    Aug 2007
    near the swamp
    806
    well that was a quick video lol
