Thread: chlorine test
    chlorine test
    do i use 001 and 002 reagent to test and then 0014 for ph is this right.
    22,543
    Re: chlorine test
    Yes, You add 5 drops of R-0001 and then 5 drops of R-0002 and compare the colors. Then with a new sample of pool water you add 5 drops of R-0014 and compare that to the pH color standard.
    Re: chlorine test
    ok great. what is the number 0003 used for it has a yellow cap i was told it was for just fc . and the 001 and 002 was for fc and bromine test. is that right or wrong .thank you so much.........
    22,543
    Re: chlorine test
    R-0003 is for the CC test.
