Thread: Installing a J bead liner
    I am trying to install a J bead liner in my pool. The liner has come loose in a couple of spots on the pool 2 seperate times. I have laid the liner over the metal ring and installed the plastic pieces over that and installed the top back on the pool and started putting water in. When I have gotten about 2' of water in the pool, it has come loose from under the plastic (Twice in two different places). Any suggestion's? It is getting awful expensive on my water bill to fill it up that much and have to drain it all over again.
    23000 gallon fiberglass pool
    hayward pro II sand filter with 1 1/2 hp motor and pump
    SWG aqua pro, dolphin diagnostics advantage robot
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Re: Installing a J bead liner
    First off, are you sure its the correst size? Are the walls completely level and even? Secondly, when you start your fill, it should be warm and more importantly, SUNNY as you slowly fill so that it can properly stretch in. Really suuny days will make the vinyl like soft butter and super pliable You may want to hang the liner so that there isnt as much tension in that area as the wall may be slightly off level
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
