Results 1 to 8 of 8
Thread: Brushing Frequency for Most Pools?
    Apr 2010
    Philadelphia, PA
    92
    I know from reading the 'pool school' info that it was recommended to only brush once per week for 'most' pools.
    My question is how often do you brush?
    In the past I have brushed almost daily. The pool always looks great, but I think I can reduce it and save some time in my busy schedule.
    Thoughts?
    Doug
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Brushing Frequency for Most Pools?
    I brush the pool once a week. I have an electric safety cover so the pool doesn't get too dirty, but brushing is mostly about wiping off any algae cells that might not be getting exposed to chlorine and to preventing biofilms -- both items that are unlikely with proper FC/CYA levels, but are helpful nevertheless. In our pool, about the only area that ever gets a hint of sliminess is the top of a ramp (see this photo and this photo) that only has about 1/2" of water over it so the circulation there is the worst of any area in the pool.
    Apr 2010
    Philadelphia, PA
    92
    Interesting. I have been contemplating going longer like I said, but at the risk of an algae outbreak, I have avoided more than 2 days without brushing.
    Doug
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Mine gets brushed a couple times a week. But it's not really a methodical brushing each time. Usually I'm outside smoking, so I'll grab the brush and churn things up a bit, or sweep a few leaves into the drain.
    SW Georgia
    300
    Since i got my cleaner I have only brushed places that have been in the outer limits of where my cleaner could reach where debris as built up. I do recognize that I probably need to revert back to weekly brushing for added insurance.
    35K IG Vinyl 20 x 40 self built pool, Hayward Pro Series High-Rate Sand Filter 31" 98gal/min, Hayward TriStar 1.85hp, Hayward 400btu heater, BBB method w/Hypo, Jazz light w/matching fiber optic rope lighting around coping w/syncronized color wheels. Concrete Paver deck.
    Mar 2007
    Coastalish 'down easter'
    4,160
    If you are pressed for time, brush everything 1X per week and the low interchange areas (top step, ladder steps [top and bottom!] and around the lights, the skimmer mouth and any protrusions into the pool) 2+ times/ week.
    It's easier to keep the algae and bio-nasties at bay than to deal with a bloom!
    Luv& Luk
    -Ted
    Apr 2010
    Buckeye, AZ 85326
    619
    I am a solid once a weeker, with suplemental brushing when we are out by the pool messing around. I have 2.5 year old son so we are out there quite a bit.
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    Jun 2007
    New Jersey
    653
    I brush about once a month. On the other hand, I refuse to have a cleaner and manually vacuum once a week--never a bloom or sliminess. We ran our old unlined steel pool and we didn't even own a pole brush for the first thirty years. We just had a hand brush for the ladders.
    What's the point of a cleaner if you have to brush all the time? I'd rather vacuum.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
