Results 1 to 11 of 11
Thread: First Test Result TF100
    opened the pool this afternoon and let the pump run for a couple hours. I just tested the water with my new tf100.
    FC - 0
    CC - 0
    TC - 0
    PH - 7.2
    TA -70
    CH - 130
    cYA - 0
    76549 Liters -- Cartridge Filter -- In Ground -- Vinyl -- TF-100 Test Kit -- AquaVac Robotic Cleaner -- UV Sanitation -- Winter Safety Cover -- Installed 2010 -- Southwestern Ontario, Canada
    Latest Test Results June 25:
    FC - 6, CC - 0, CYA - 40, CH - 110, TA - 90, pH - 7.5
    Re: First Test Result TF100
    Your numbers look good. Of course you need to add some chlorine and CYA.
    I recommend adding 2 ppm of chlorine this evening and starting to add CYA soon.
    Nov 2010
    Calera, Al
    271
    What does your water look like?
    17,000 gal, IG Gunite Diamond Brite plaster Kidneybean,w/7x11 tanning ledge& 3x5 swimout bench,244T 300lb Hayward Pro high rate sand filter(63 GPM) , Hayward 1Hp Super Pump w/3/4 hp booster pump, Polaris 280, Laars Lite 2 175k N/G Heater, Tf-100, Speed stir
    The bottom of the pool has a layer of dirty. The water is clear
    I am going to pick up some bleach tomorrow and add it to the water.
    What level should I shoot for CYA, the range says 30-50. Should I aim for 30, 40, or 50?
    Just to confirm I am using the Pool Calculator properly:
    CAY from 0 - 50 = 3827g
    FC from 0 - 2 = 2480ml 6% Bleach or 3721 ml 4% Bleach (I thought last time I was at WalMart their Bleach was 4%)
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by Easto
    I suggest you aim for CYA 40. You can test and adjust after a week or so.
    Yep, you are using the pool calculator properly
    You're done SLAMing when:
    Quote Originally Posted by Butterfly
    awesome, thanks
    I added +/- 3000g of CYA. Originally I put it in the skimmer basket ignoring all suggestions in the pool school. The stuff sat in there like mud. I scooped most of it out into a skimmer sock and about 2 handfuls went directly into the water and is now sitting on the bottom of the pool.
    1. Should I vacuum this stuff up and let it run through the skimmer, pump, and filter?
    2. I have a CYA ball the size of a grapegruit in the skimmer sock. How long will this, should this take to disolve?
    I also added 3.75 L of 4% Bleach. Picked up 5x5L jugs of 4% for $1.99 each. Should get me to 2ppm FC
    It is best to vacuum up any CYA sitting on the liner.
    The CYA in the skimmer will usually dissolve in four to six hours with the pump running, but it varies somewhat.
    I moved the sock of CYA over to a return jet and this was 100x better. I can see the lump of CYA getting smaller and smaller.
    Jason, I added 2ppm of Bleach to the pool. What's my next step? When should I test the water again?
    Starting this evening you just start treating the pool as routine day to day maintenance. In this case that means raising FC to a level suitable for your CYA level. You can assume that CYA is 40 for now, so the day to day FC level is between 3 and 7. For now I suggest that you raise FC to six this evening and see how it does between now and tomorrow evening.
