Results 1 to 8 of 8
Thread: Don't forget to switch from 'waste' back to 'filter'...lol
    Apr 2009
    Burlington, ON, Canada
    344
    OK..bonehead move of the season (so far).
    We've had excessive rain here. Yesterday I woke up to find the water level was well over the top of the skimmer. This was around 9am. My pool has the Jandy Aqualink PDA system and is programmed to come on at 11am. So, at 9am, I switched the multiport valve to waste, turned on the pump manually and lowered the water to below the top of the skimmer. Shut the pump off and went out on errands. (does anyone notice I've missed a step??)
    At 130pm, I came home to find the pool about 12" lower than when I left, the pump running merrily away with no water in it, and the pool water level, of course, below the bottom of the skimmer. The filter was still in the 'waste' setting. So, my perfectly balanced water was in the sewer, and I had to add water to get the level back where it should be. Goodbye to perfectly good stabilizer I had just added, salt, chlorine, etc. etc.
    Still, this is the first time in 4 years I've done this...and hopefully the last. I hope I haven't taken years off the life of my pump.
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star VS900 (1.85 HP) pump, Hayward C3030 cartridge filter
    Nine Techno Solis 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Don't forget to switch from 'waste' back to 'filter'...l
    We all make bonehead mistakes
    Check under the pump housing/ motor interface for drips (you may have fried the seal assembly )
    Luv& Luk
    -Ted
    38,290
    Lost a lot less than I did when I moved my multi-valve from recirculate to filter before going to bed. Turns out the spider gasket was messed up and was sending some water to waste. Woke up to a 60% drained pool ... well below the skimmer which must have sealed enough for the water to continue to be pulled from the main drain.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,602
    (been there---done that)
    Apr 2010
    Philadelphia, PA
    92
    Or how about adding water to the pool. Setting an alarm on your phone to remember to shut off the water. Dismissing the alarm. Then forgetting to turn off the water and overflow the pool?..... twice last year!!
    Argh!
    Doug
    38,290
    I have definitely overfilled our pool a couple times ... once remembering when we were at someones house for a BBQ. Luckily the water runs away from the house and to the palm trees. After a couple times of that, it was decided to add an auto-fill when we did our resurfacing. Problem is now that a leak developed in supply to the auto-fill and I have yet to removed the brick walkway to dig it up and fix it .... so back to setting the timer and hoping to remember to turn it off.
    Apr 2010
    Philadelphia, PA
    92
    Got to love it!
    Doug
    SW Georgia
    300
    My multi port valve on my Hayward filter did not disengage all the way when I switched from rinse to filter. Thankfully I heard the water running from the backwash line and fixed the problem. Apparently you need to make sure the lever pops into place.
    35K IG Vinyl 20 x 40 self built pool, Hayward Pro Series High-Rate Sand Filter 31" 98gal/min, Hayward TriStar 1.85hp, Hayward 400btu heater, BBB method w/Hypo, Jazz light w/matching fiber optic rope lighting around coping w/syncronized color wheels. Concrete Paver deck.
