Thread: Water level drop - what is normal?
    el_steak's Avatar
    Aug 2007
    Ottawa, Canada
    110
    I've had my pool for 2 weeks now.
    During that period, the water leve has dropped by about an inch. There was little to no rain, but it was not excessively hot either (75f during the day, 55f at night).
    Should I be worried about that or is this normal?
    14X24 ig vinyl pool 3ft-4 1/2ft deep - 7000 gal
    Aqua Genie skimmer and return - no main drain, 1 hp hayward pump, 27" Hayward filter with Zeobrite,
    Aqua Logic P4 controller + SWG, 2 lights
    192 square feet of solar panels controlled by P4, 5KW electric heater (just in case...)
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    With splashout and evaporation, that's reasonable. There are many variables to evaporation: Temperature difference between the water and air, humidity, wind and use of a cover.
    el_steak's Avatar
    Aug 2007
    Ottawa, Canada
    110
    I did heat the pool to about 80 degrees for the first week, so that may be a factor. No cover on the pool during that period.
