Thread: Pool is still cloudy
    At the suggestion of a local pool store, I pumped in 3 5-gallon liquid chlorine into my salt water pool and still after 24 hrs running filter, pool is still cloudy. It seems as though the jets are pumping cloudy water back in. Water is clean and was tested. HELP!!!!!!
    Re: Pool is still cloudy
    Welcome to TFP!
    Could you post a full set of water test results? There are many different possibilities. Test results will narrow it down a great deal.
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    421
    Its possible that your salt cell need acid wash or cleaning. When they get full of scale they just pump it back into the pool. Often you will see white on the bottom below the returns? And as noted what are your numbers?
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
