Thread: Easy Touch heater control, does it integrate scheduler?
    Oct 2010
    Eastern TN
    172
    I'm still setting up my Easy Touch VS3050 and heat siphon digital heat pump. The heat siphon can be controlled by the easy touch. I'm wondering if the scheduler is set to run pump a certain number of hours per day does it send signal to heat pump to run based on temp of water alone or does it wait for scheduler to turn on the pump?
    The heat siphon has a flow switch so it can sense when to turn on and a digital controller to set temp. The heat siphon displays set and water temp so I've been ambivalent about hooking it to the EasyTouch controller. I'm not sure of the benefits and minuses of either setup. Suggestions?
    Plaster pool inground 22,000 gallons with spa. Pentair Intelliflo, IC40 salt generator, WiFi control/Easy Touch.
    Hayward 1.5 HP pump on 750 gallon spa. Sand filters. Auto chlorinator on spa. Auto water level. Dolphin M500. TF100 XL with Speed Stir. Apera Instruments AI311 PH60 Premium Waterproof pH Pocket Tester
    Re: Easy Touch heater control, does it integrate scheduler?
    The Easy Touch can change the pump speed when the heater is on only if it is controlling both the pump and the heater.
    The Easy Touch will only turn on the heater when it has the pump on because of a programmed schedule. It won't run the pump just because the water is cold unless you have solar.
    Having everything integrated through the Easy Touch is best.
