Thread: Pentair PG2000 shorting out system
    I have a Pentair PG2000 that is shorting out my entire system at the main circuit breaker every time I attempt to turn it on. The air vents are clear and the area around the unit are dry and from what research of done those two situations would seem to be my problem. Has anyone had this happen either with this particular unit or something comparable. Im not very knowledgable with electrical work so any help would be greatly appreciated. Thanks.
    Pool: 25,000 gal.(appx.)/IG/Vinyl/DE
    1.5 HP superpump / Filter Flow Rate - 72gpm (as per spec.)
    Hayward 300,000 BTU natural gas heater / Polaris 380
    Long Island, NY
    May 2011
    Berea. KY
    34
    Re: Pentair PG2000 shorting out system
    hello do the wires get hot if you touch them, you may need a lower gauge #10-8 size wire. or you may need to install a larger circuit breaker.
    Cole Pocius
    15'x30'x52" AG, 1 HP Hayward Power Flo, Hayward per-flex D.E filter, Aqua luminator. chlorine, baracuda beta. vinyl liner, 12,500 k gallon
