Results 1 to 8 of 8
Thread: Happy bottom vs. perfect pool bottom vs. gorilla pad
    Hi all- We are planning an ABG to be decked up and left semi-permanently in place, so I am looking for the pool pad with the best durability. The pool we are getting has a 10 year warranty, so I'd like a pad that will last at least that long as well. So far, I've been able to determine:
    1. Happy Bottom has NO warranty;
    2. Perfect Pool Bottom (which I hadn't even heard of as long-time lurker here) has a 10 yr warranty; and
    3. Gorilla Pad - ???- can't find any info.
    I know #1 and# 3 serve somewhat different purposes (padding vs. puncture protection:) do people use both??
    Also, how long do they last in anyone's experience, even if not warrantied?
    #2 looks like it serves both purposes but is quite a bit more expensive, and isn't available in the size we want: we'd have to cut it way down.
    Thanks - you guys (and gals) are great. I followed all your advice for last year's cheapo starter intex but am ready to move up to a more semi-permanent pool this year - whew, things get complicated quickly !! -MNmom
    14X28 inground Vinyl
    1HP Super II Pump
    200lb Sand filter
    Tri-chlor, bleach shock
    BBB
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Re: Happy bottom vs. perfect pool bottom vs. gorilla pad
    I can't tell you how long they last, with or without the warranty. What I can tell you is that I watched a friend install Happy Bottom and swam in the pool after it was in. It does have pieces with taped seams. It was ok. It did make me decide to order Gorilla Pad instead when we did our last liner replacement and I really love it. One piece construction, cut to fit your pool size, feels thicker than the Happy Bottom, it's a really thick-stretchy felt type material, don't think anything is growing through that stuff and the bottom feels sooooo nice. One of the nicest things we did for our pool. We had a plain sand bottom before with a sand cove. Gorilla pad, wall foam and foam cove. Much nicer, smooth. Wonderful.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    MNmom- Welcome aboard!
    Not to add confusion but another choice is styrofoam. The 2" pink, or yellow from the building supply store. It insulates the bottom of the pool from the cold ground, gives the floor of the pool a very nice cushion and protects the pool from rocks creeping up throught the floor. I have been using the same foam for about 10 years. and mine was taken up and stacked w/o any covering all winter. For the last 2 winters the foam has had my boat sitting on it w/o a problem. My setup is 6-36" of class 5 screened and tamped every 3". Aprox 1/2-1" of sand compacted, just to smooth and level the area. 2" pink styrofoam, gorilla tape on the seams, cut into a 18' foot circle. HD silver tarp covering the foam. 3/4" river rock 1' wide around the pool.
    Most of my build here: planning-piping-and-questions-now-with-pics-t12625.html
    Mike
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
    Jun 2013
    Oklahoma City, OK
    1
    Just wondering which pad you went with and how your pool is holding up. We are working on installing a 16'x48" Intex above ground and we want to make it last.
    5K Gal, AG, Intex 16' X 48" Ultra Frame, Just purchased, Working on Install as of 6/22/13
    Jul 2014
    Houston, Texas
    5
    Question Re: Happy bottom vs. perfect pool bottom vs. gorilla pad
    I am in the midst of planning out my first AGP install and was also wondering if you simply leveled out the ground and put the Gorilla Pad down and the pool on top. I am reading so many different opinions about leveling with sand, or a clay based sand, etc etc. My head is spinning. I just need help as I peruse this site. Thanks.
    Helena
    Intex Ultra 18' X 9' X 52" (4,545 gal) AGP
    Intex Sand Filter Pump Combo 1,050 gph
    Intex Krystal Clear Saltwater System 15,000 Gallons
    Gorilla pad sitting over crushed gravel base
    jmcdtucson's Avatar
    Jun 2014
    317
    I used 1/4" foam (FOAMULAR brand) and the bottom is divine. Don't know if it will hold up, but everything I've read says it will.
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
    Jun 2013
    Manitoba, Canada
    153
    Regardless which one you put under the pool, it will outlive the pool for sure.
    Jun 2013
    Manitoba, Canada
    153
    Gorilla pad is a fiber blend, kind of like a super heavy duty 1/8" thick landscaping cloth, but really tough. Happy Pool pad is a 1/4" foam pad. Perfect Pool bottom is a polymer with a 10 year warranty. http://www.gladon.com/perfectpoolbottom.htm
    They all do the same job, depends on the price really. Shop around, check on line, etc.
