Results 1 to 11 of 11
Thread: Pool Opening?
    Jun 2010
    Piketon, OH
    17
    Pool Opening?
    Just opened the pool today. Everything went smooth with the start up. My only issue is the psi on the filter is running at 50. Do I just need to backwash? Last year it mostly ran around 20. I want to get the water circulating so I can test and start adding chlorine. The only thing I tested before I turned on the pump was pH. Is that correct? It was 7.5. Sorry to ramble. Thanks!
    30,000 Gallon IG pool, vinyl, Aqua-rite T-cell 15 SWG, 1 1/2 HP with Tagelus TA60D sand filter 60 gpm
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Pool Opening?
    Sounds like a bad guage or possibly your returns are still plugged When you turn the pump off, does the PSI guage return to zero? With the pump running, do you have good flow at the returns?
    Jun 2010
    Piketon, OH
    17
    Re: Pool Opening?
    Never even thought to check with pump off. When I tried only went down to 30. Returns all flowing fine. Could 30 actually be my zero point? At 50 if didn't seem to be running hard like I would expect. Should I go ahead and test my water after running for 1 hour and them get chlorine to shock level based on my CYA?
    South Central NJ
    3,192
    Re: Pool Opening?
    Replace the gauge. Any reading is now suspect. They aren't expensive.
    Scott
    Owner of - PoolGuyNJ LLC
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Pool Opening?
    As Scott mentioned, I would replce the guage. Test after 1 hr and adjust PH 1st, if needed, then you can raise FC to shock, but not required if you open to a clean pool and an FC residual. Post up your results and we can guide you from there
    Jun 2010
    Piketon, OH
    17
    Re: Pool Opening?
    fc 0
    cc 0
    tc 0
    pH 7.8
    t/a 120
    ch 250
    cya 50
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Pool Opening?
    Looks good. Adjust PH to 7.2, this will lower TA some which is a bit high for a SWG pool. Bring it up to shock (FC of 20 with CYA at 50) and if the water is clear and you can pass the overnight FC loss test, you should be in good shape, if not continue shocking. After you are done shocking, you can raise your CYA to 70 or so, if you plan to continue to use a SWG.
    Jun 2010
    Piketon, OH
    17
    Re: Pool Opening?
    My SWG stopped working last year and I don't think I will replace it right now so the pool is basically the BBB method. Do I still need to lower my pH and TA or should I just go ahead and shock? If I do lower pH, how long should I wait after I add the acid befor adding the bleach?
    Re: Pool Opening?
    I would go ahead and lower the PH anyway, though it isn't nearly as important if you don't have a SWG. Wait half an hour after adding acid and then double check the PH to make sure it didn't accidentally get way off somehow before adding chlorine.
    Jun 2010
    Piketon, OH
    17
    Re: Pool Opening?
    I replaced the pressure gauge and it is reading 16 which is more like normal. I have shocked the last 2 nights and plan to do an overnight test in the am. Here are my numbers from tonight.
    FC 15
    CC 0
    TC 15
    pH 7.5
    TA 130
    CH 280
    CYA 40
    temp 45
    Am I on the right track? If I don"t lose any chlorine in the am then bring it back to normal range?
    Thanks for the help
    Re: Pool Opening?
    Yes and yes. You are doing well, and an overnight loss of 1.0 or lower and clear water means you are done.
