Thread: borax before or after AA stain elimination
    Battled the brown stains with AA, looked wonderful, used a metal sequistering agent and all was good for about 5 days, right until the green alge started.
    Had to shock to get alge under control. water is now balanced, Should I AA again or add borax/acid first then drop cl levels to add the AA?
    23000 gallon fiberglass pool/ ugly brown stain all around
    SWG ,aqua rite
    cl 5.5
    TA 80
    ph 7.57
    cya 60
    hayward pro II sand filter with 1 1/2 hp motor and pump
    SWG aqua pro, dolphin diagnostics advantage robot
    Re: borax before or after AA stain elimination
    Adding borax and acid can cause large swings in the PH, which can cause stains to appear. Thus, it is best to add borax/acid before doing an AA treatment. Give it three days after adding borax before starting the AA treatment.
