Thread: To drain or not to drain...
    May 2011
    Rochester, MN
    44
    Hey guys, I am contemplating draining my 24ft above ground pool, which has a vinyl liner, to get rid of some stains that I have been unsuccessful at clearing with traditional methods (vacuum, broom, etc). The stains at the bottom of my pool are in small crater like pockets, which I believe are related to the previous owner failing to pack the soil appropriately before inserting the liner. I have heard conflicting information regarding draining above ground pools with vinyl liners.
    Currently my pool is a little less than half full with a fair amount of debris at the bottom. Am I better off draining the pool and attempting to manually clean the bottom with some sort of chemical (recommendations?) or should I clean out the bottom of the pool the best I can with my current water level and hope the conversion to chlorine from baquacil is enough to take care of these stains?
    As a side note, I have been using Baquacil since I lived in my house as this is what the prior owners suggested, but I will be converting to chlorine this year.
    Are there any certain methods that work well at getting rid of widespread debris at the bottom of the pool, rather than using the typical net connected to the pole?
    Thanks for any advice!
    Matt
    24ft round AG, 13.5K Gal, vinyl, 1.5HP Pentair Dynamo pump, 22" Pentair Meteor sand filter
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,429
    Re: To drain or not to drain...
    It is common for above ground pools to have small indentions in the floor. The stains are probably organic in nature and should clear up with bleach. I would go ahead and refill the pool and start the chlorine conversion after scooping and vacuuming out the debris on the bottom.
    Read the Pool School article on baquacil conversion before you get started.
    Love TFP? Become a
    TFP Supporter!
    30,432
    Simply for reinforcement, "Ditto" what zea said!
    May 2011
    Rochester, MN
    44
    Thanks guys, I appreciate the advice! Any tricks to cleaning out the debris at the bottom of my pool in a more timely fashion than using the pool vacuum and/or sifter?
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Welcome to TFP...a leaf rake and 30 minutes of elbow grease will do wonders
    FWIW, your pool is likely closer to 13.5K Gals vs 15K. Not a big difference, but just in case you find your numbers to be off a bit after chemical additions, you'll want to estimate pool volume using avg water depth vs pool wall height.
