Thread: Total Hardness
    Total Hardness
    My water hardness is off the charts high. We had a leak last year, had it patched and slowly put some water in from our well.
    Winter is over. Trying to adjust and add as needed. But how to I get the hardness level down? Should I try and use water softener salt?
    Any help is appreciated...
    approx. 26K inground
    vinyl liner, hayward 1hp pump, 200lb sand filter
    manual vac.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: TOTAL HARDNESS
    Welcome to TFP!
    There are only two ways to lower hardness: Replace the water with lower hardness water like rainwater, or have the pool water filtered with a reverse osmosis system. Only limited areas have RO filtration available for pools.
    A water softener performs an ionic exchange to replace the calcium with sodium, so it won't work in a pool unless you pump all the water out and pump it through a softener, which wouldn't be an easy process.
