Results 1 to 8 of 8
Thread: While vacuuming I see dirt returning to pool?
    Mar 2011
    North Carolina
    34
    While I am in the process of trying to clean my pool, I am running the navigator to vacuum some and while doing so, there is dirt/debris going straight back into the pool via the returns, what could be the problem? I just today replace the spider gasket thinking maybe thats the culprit. Now Ima draining the sand filter so I can look at the sand, but draining the water from the sand filter is a slow go. What should I be a looking fer as far as the sand goes???
    Foxx Pool Grecian 27000 gallons (vinyl liner)
    Sand Filter w/ 300 #'s of Brand New Sand 6/3/11
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: While vacuuming I see dirt returning to pool?
    Low sand level or sand that wants to retain its shape and not lay naturally would be the most common things. The latter can result in channels that the water can use to bypass the sand.
    Mar 2011
    North Carolina
    34
    Thing is I am not exactly sure how much sand it holds and for that matter how much is in the filter, can I buy some and put new over old???
    Mar 2011
    North Carolina
    34
    Mar 2011
    North Carolina
    34
    Mar 2011
    North Carolina
    34
    stirred up best I could, yeah green algae does = green sand huh
    Puffin's Avatar
    Jul 2010
    Metro Atlanta, Georgia
    217
    Quote Originally Posted by JohnT
    FYI -
    Here is an interesting thread I found while looking for something else, that covers channeling http://www.troublefreepool.com/my-sa...26.html#p60821
    19,600 gal, Vinyl, Grecian L, StaRite Dura-Glas 1 HP pump, 3/4hp booster, Pentair Clean and Clear 420 Cartridge filter
    The Pool Cleaner 4x, PoolSkim
    Mar 2011
    North Carolina
    34
    Thanks for the tip
