Thread: Skimmer repair
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    352
    Skimmer repair
    Opened the pool this year and have discovered a leaky skimmer gasket. Since I have to pull it out to fix it, is it worth the added expense to change to a winterizing style? I'd rather not have to add as much salt, borax, etc. next spring. My question is: How well do they work?
    Thanks
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 1hp Pentair Superflo pump.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Skimmer repair
    If I had an AG pool, I'd want the Aquadoor on the skimmer.
    They work well as long as the "Tupperware" door is fully sealed (easily done with a rolling pin ).
    {EDIT} remove stutter stutter }
    Luv& Luk
    -Ted
    Feb 2009
    352
    Re: Skimmer repair
    Thanks! Now is that a marble rolling pin or wood....?
