Thread: Skimmer Line Clogged
    I opened my pool last Sunday and after testing water saw my CYA was low along with some other numbers being off. I am trying to bring things in balance and Monday night added HTH Stabilizer and Conditioner. I put in half a bottle into the skimmer and it seemed to draw into the line. Then Tuesday morning I put in the remaining half of bottle and again seemed to go in just fine. I went to vacuum the pool today and put the suction cap on top of the skimmer and could not get it to seat properly. I then removed the skimmer basket and found the bottom had a lot of CYA and it was clogging the skimmer pipe. I scooped out what I could by hand but the pipe is still clogged. I tried cleaning the pipe as best as I could by trying to break it open with a thin piece of metal rod and a screw driver. Went down in the pipe pretty far but clog still exists. Any ideas what I might try next to clear the line?
    18,000 Gallon in ground Vinyl Pool
    Intelliflo VS Pump, Quad DE60 Filter, Intellichlor IC60, Easy Touch Control
    Ottawa, ON, Canada
    153
    Re: Skimmer Line Clogged
    Suck only from the skimmer and not the main drain? You should really let the cya dissolve in water using a sock instead of clogging your lines though..
    19.5k gallons in ground, P4 panel with turbocell SWG, 1hp Hayward superpump II, sand filter, Heater low nox 250k btu heater, solar cover on rocky roller
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    It will dissolve eventually. You might be able to break it loose by putting a hose through the pump basket into the inlet pipe. Turn the drain off and wrap the end of the hose in a rag to get a seal in the pipe.
    I did try turning off the main drain but that just caused the SVRS on the pump to shut it down. I hope to pick up a drain king tonight to try and break it loose. If I can't find one I'll try the rag. Thanks for the suggestions.
