Thread: Help, Polaris 480 Pro Moves when Booster Pump isnt on. Hmmmm
    Hi
    Our Polaris is moving around the pool (very slowly) without the booster pump on. Not sure what is going on here.... this is the second season with pool and I don't recall this happening last summer!
    There is a small amount of water coming out of the hook up port (where the cleaner attaches to the pool), but this seems to be consistent with the amount of water that came out of it last year.
    Any ideas what is causing this and what i should do?
    I ordered a new release valve, just in case that is the problem.
    other than that i'm stumped.
    thanks!
    Apr 2011
    Fresno, California
    46
    Re: Help, Polaris 480 Pro Moves when Booster Pump isnt on. H
    That is normal. I actually added a ball valve between the booster and return to stop water flow to the cleaner.
    23k IG. Plaster. StaRite system 3 Cartridge Filter (S7M120), Pentair MiniMaxNT Heater. IntelliFlo VS (8 Speed). Going BBB
    that was easy..thanks!
