Results 1 to 12 of 12
Thread: Noisy Hayward sand filter
    just bought a home with a 18K pool. Previous experience has only been with SWG pool. In addition to fighting algea, my Hayward multiport valve makes a cavitation noise when on Filter setting. Reducing flow does not work, and I have verified no leaks on pump suction. The noise goes away when I change to backwash, waste, recirculate, or rinse settings. I tried installing a ball valve at the pressure gauge to bleed out air, but no luck. Pressure downstream of the sand filter runs about 18# and I have verified good return flow. Any advice on what to try next?
    Re: Noisy Hayward sand filter
    Welcome to TFP!
    Have you tried opening up the multi-port to see if there is a pebble in there bouncing around or a cracked piece of plastic or anything like that?
    Glad to find the site. Had a bad experience at Leslies today, came home and found you guys. I did take the valve apart and it looked good as new. Verified O-ring was in good shape. Still cavitation noise only on Filter setting.
    Aug 2007
    near the swamp
    806
    I just had this same problem on one of my customer's Hayward sand filters. Turns out all he had to do was backwash it for a good bit, he backwashed for 10min and rinsed for 5min.
    I back flushed for 15 mins and rinsed for 5. Noise did not go away, but I will keep trying. I did confirm from previous homeowner that the sand was replaced 3 months ago
    30,429
    Hmmm. If you're getting that rattle on filter mode but not rinse (or any other) that certainly points to the multi-port as the culprit. Are you pretty sure the sound is coming from the multiport? What is the psi on "rinse"? Similar to the 18 on "filter"?
    The pressure decrease 2 psi in rinse mode. I'm fairly certain it is the valve, but I'm new at sand filters so I'm not 100% certain.
    Apr 2011
    Warner Robins, GA
    245
    Both of My Hayward S210 filters with multiport valves, have made this noise in the past. I find that while the pumps is running and in "filter" opening the top screw on the filter will bleed the air out.
    Good Luck.
    16 x 32 Grecian Vinyl. Salt-Aqua Plus PS-4, Hayward Pro Series Sand Filter, Hayward Ecostar SP34000vsp, Gulfstream HE-125-T-A Heat/Cool heat Pump
    Thanks for the tips, however none have resolved the problem. One more piece of data: today my back pressure on the filter increased 10 psi after a hard rain. The valve was quiet as i have ever heard. After a long backwash and rinse cycle, the pressure decreased and the noise returned.
    Apr 2009
    Burlington, ON, Canada
    344
    Why would the pressure go up 10psi after rain?
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star VS900 (1.85 HP) pump, Hayward C3030 cartridge filter
    Nine Techno Solis 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
    Apr 2011
    Warner Robins, GA
    245
    What is your clean pressure? Are you exceeded the GPM rating of the multivalve?
    Filter pressure went up due to dirt and leaves in my pool after bad weather. My clean filter runs about 20 psi
