Results 1 to 11 of 11
Thread: When to change out filter sand?
    thepiratemorgan's Avatar
    Aug 2010
    Central NY
    185
    First, thanks for all the help late last summer with my pool problems. With a TF-100 testing kit, some reading (ok, a TON of reading), using the BBB Method, and help from several members here, I was able to overcome an algae problem and learn the "method of madness" to pool chemistry.
    Now with that said, our pool was installed May 2007 and this year will be our fifth season. Would like to know the recommendation for changing out the sand in my Hayward Pro filter?? I've read the manual and it doesn't say.
    I know my grandfather, God bless his soul, NEVER changed the sand, and ran a pool filter for close to 20 years or more before getting a new pump and filter system. But I don't want to go the way of the "old school" process. (Sorry Gramps!)
    14,600g / 24ft. Round Above Ground with Solar Cover
    18" Hayward Pro Sand Filter
    1 HP Hayward Powerflo Matrix Pump running 10am - 8pm
    Full Sun (when we get sun ... LOL): Approx. 10am to 7pm
    Using the Trouble Free Method, and loving it!! Arrrrrrrr!!!!
    22,551
    Re: When to change out filter sand?
    Your gramps was a pretty wise man (hats off to him). You don't need to change the sand unless you see that there's a noticeble reduction in filtering that can't be attributed to something else.
    However, if you just want to change it. the easiest way is to drain all the water out through the drain and then vacuum the sand out witrh a wet/dry vac. To replace it, you cover the stand pipe and add about a foot of water and gently pour the new sand in there. Put the filter on [edit] backwash for a few minutes then[/edit] rinse for a few minutes once buttoned back up and you're good to go.
    Aug 2010
    Central NY
    185
    I learned tons from my gramps!! And I have to apologize to him for doubting his old school ways. Thanks for your reply. I guess that answers why they don't put in a "sand exchange" schedule or some other form of annotation in the manual.
    Mar 2007
    Coastalish 'down easter'
    4,160
    One quick thing, on what to do after the new sand is in) I believe the proper method is to backwash first, then rinse - if I'm wrong, I've been doing it wrong for over 20 years
    Luv& Luk
    -Ted
    22,551
    Dangit! Thanks for catching that for me Ted. I've edited my post to include that.
    I just ordered the zeolite sand replacement for our sand filter. Has anyone replaced sand with this alternative? I am hoping it will deliver clearer water as promised.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    In my personal opinion sand will generally last the life of the filter, by the time the seals are all shot, the nuts and bolts are rusted, the handle breaks off the multi way valve, etc. I generally decide it is time to change out the filter sand and all, easier than trying to empty the sand if you have the equipment to handle it.
    Ike.
    Apr 2011
    Houston TX
    2
    My previous house was a rental and it had a pool with a sand filter. I always had a fine sediment on the bottom of the pool that didn't get captured by the sand filter, it would get kicked up when we swam and cloud the water. The sand was approximately 10 years old. I replaced it with zeolite sand and never had the fine sediment anymore, it became crystal clear. It also lowered my filter pressures by about 5psi. If I recall, the zeosand cost about 3X as much as regular sand. I will eventually change my current cartridge filter to a zeolite sand filter as I have to clean my cartridges about once a month. It wasn't that hard to flush out all of the old sand from the drain hole in the bottom of the sand filter with a garden hose, you have to be careful not to break the plastic filter grids if you try to scoop the old sand out.
    Houston TX, in-ground 13'x30' 14Kgal, pebble tec surface, Jandy Ei 110v SWG, Del Oz. Eclipse 2 ozone, jandy CL340 cart filter, 2hp main pump, 2 1hp pumps for polaris and waterfall, jandy rs6 controller. pool built 2004, ozone and SWG 2010, photo link: http://s1192.photobucket.com/albums/aa3 ... 040051.jpg
    30,426
    This thread is getting slightly hijacked but OP's original questions seems to have been answered......many of us have NEVER changed our sand and have no intention to do so.
    Secondly. a properly operating sand filter can (ansd usually does) leave your pool crystal clear. Sand is a perfectly acceptable filter medium which sort of explains why it has been around so long. Zeo hasn't been around that long and users on this forum have very mixed reviews....certainly enough negatives to raise eyebrows a bit.
    If you have water clarity problems, the solution is frequently found in proper water chemistry or, less likely, some type of mechanical damage to the filter. Less often, the pump and filter are simply not being operated long enough to keep the water clear.
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Sometimes too agressively backwashing can result in sand loss so minor additions of new sand may be needed. I have cleaned my sand and sometimes add a bit of DE to polish the water. Ive never replaced the sand.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Aug 2010
    Central NY
    185
    Thanks to everyone for the clarification and I guess I will leave the sand well enough alone. But I guess I should at least check it's level every so often, or maybe not because I truly don't aggressively backwash. I usually wait until pressure is up 10psi over the norm.
