Thread: Autopilot Cell Life
    donaldm823's Avatar
    Cape Coral, FL
    147
    Autopilot Cell Life
    My Autopilot Digital DIG-220 amp-hr counter indicates my SC-60 cell now has 15133 amp-hrs. Cell visual appears like new with all blades the same length and no deposits. My question is, what is the rated cell life? When I bought the unit it came with a flat 5 yr warranty, but I have read in some posts 10000 hrs and others it was 10000 amp-hrs.
    Should I be buying a replacement cell now so I do not get caught with a sudden failure? What is the rated amp-hrs and is there something specific I should look at to anticipate cell end of life?
    I am meticulous about water chemistry and balance. This season will be season 4 on the autopilot and my seasons are typically 5 months of SWG run time at 10-12hr per day with a 40-50% settings (today it was 25% since still cold out).
    Don SW Florida
    10,000 gal in ground concrete pool
    Pentair Cartridge filter, Pentair SWG, Pentair Intelliflow VS pump (11018)
    FAFCO solar panels w/Pentair SolarTouch controller
    using BBB for pool chemistry/Lamotte ColorQ tester for daily testing
    Re: Autopilot Cell Life
    I don't think that AutoPilot officially specifies the cell life time, other than the warranty coverage. Still, the cell life should be somewhere around 10,000+ hours turned on, or somewhere in the vicinity of 60,000 to 90,000 amp hours.
    Your cell should have a number of years left in it yet. I wouldn't worry about getting a new cell until there are some signs of the cell aging.
    donaldm823's Avatar
    Cape Coral, FL
    147
    Thanks Jason-good info that typical SWG cell is 10,000hrs NOT amp-hrs. Since my amp-hr reading on the Autopilot is 15,000 amp-hrs and my amps are usually 5 amps, it looks like I have only 3000 hrs on my cell after 3 pool seasons. I oversized the cell for my pool so I usually run it at low power and low percentage settings
    Don SW Florida
