Thread: DE Filter question
    DE Filter question
    Anyone know what the following is in the image? I thought water was flowing through there now I don't see water. Does this mean my filter is clogged?
    25k Gallon Gunite Inground Pool
    Pentair FNS PLUS DE filter
    Pentair WhisperFlo WF-24 (seems like single speed)
    Bel Air, MD 21015
    Re: DE Filter question
    That looks like a check valve. You can't always see the water moving when it is free of bubbles.
    The two best ways to check if your filter is clogged is to feel the force of the return jets, if they are weak then the filter probably is clogged, and to watch the pressure gauge on the filter, when the pressure is high the filter is clogged.
    ok thanks a lot Jason!
    Bel Air, MD 21015
