Thread: Auto Clear Plus fuse location
    I have an older model AutoCLear Plus SWG
    I do not see a fuse in the controller? (to the left of the cell chord)
    Does it have one?
    I did find the fuse for the transformer and it is in working condition.
    I have an error 94 message and have tried all I can.....(Salt,chord,temp, etc.)
    Should I just replace the cell or buy a new controller?
    Thank you
    23,000 gallon inground free form pool with spillover spa, Paramount in floor auto pool cleaner, Hayward C17502 filter, Andrews Advantage Series heater, 2hp Pentair WhisperFlo 26 pump for in floor auto pool cleaner, 2hp WhisperFlo 28 pump for pool filter
    Apr 2011
    Ottawa Canada
    10
    Re: Auto Clear Plus fuse location
    I assume the model is no longer generating chlorine. You can log on the Polaris website and chat online for a solution as they still support Autoclear SWG. Worked well for me with my Autoclear SWG that wasn't generating Chlorine and had an error. I had the cell for 6 years which is past normal end of life numbers. I replaced the cell which fixed my problem.
    20x40 IGP Vinyl, 120,000L
    Hayward sand Filter
    Pentair Intelliflo (19gpm max)
    15 boxes(@4x10) of Enersol Solar Panels(S,E,W), Pentair solar controller
    AutoClear SWG, Kreepy Krawly
    Clear Vinyl Solar Cover, with solar reel, turning-your-green-swamp-back-into-a-sparking-oasis-t4147.html
